I would say that depends entirely on the equipment and the beans that you're using, the time of day, humidity, external temperature, etc. It pays to play around and 'temperature surf' until you find the sweet spot of the coffee that you are working with. I usually use the same single origin beans at home, but tamp and grind can vary from day to day, depending on all of the above, and how old the bans are... P
