VBM Domobar Super pump issues...
Morning Cremas,
In September we needed our pressurestat replaced as it had started leaking.
The tech replaced the original with a Sirai one, not the same as before but all was okay.
Over the past week or so the machine had developed an odd problem.
When extracting, the pump starts, goes through preinfusion, then takes off but when it gets to 8 bar it basically backs off to near idle and the pressure then begins to drop. Needless to say the extraction is slowed and average.
Shut it off and pull the lever again and the pump is at super low level. Leave it for a while and then it will kick on as per normal but again go through the same routine outlined above.
This morning went to purge the grouphead and was at least 45 seconds to 60 seconds before any water came out........
Anyone got a lead on where the problem lies?
Faulty pressurestat?
Blockage?
Cheers
Rider
