hahaha, they've all got you by the bollocks when you trade up, as you know once you've started buying nice lenses...you're stuck....because it will (unnecessarily) cost you lots of money to change over ! So I am a Canon man because that was where I started ! BTW thanks. I thought it turned out really well (should see it in original format on full screen before resizing down to suit loading it into the website). Its only a car, but the photo (as always) makes it look 10 times better than it does in the flesh. Photos are like paint (if you are lucky enough to do them well occasionally)..... a coat of paint hides a thousand sins, and a good photo makes something look better than it really is (so, same story).
