I understand it is not going to taste the same, but it should taste at least as good, not worse? If I use the same beans/dose but grind with the Rosco I get thick syrupy extraction with lots of crema and a better taste. so it can only be the grinder or the grind setting, I will play more with grind settings. I have written to Craig at HG one for any tips and advice.
