Click Clack principle is good... but only removes free flowing grinds.
- Sweeping the chute does a little and or cleaning the doser does next to nothing....
[/li] [/list] If on a clean system; if you were to weigh and grind, then even after cleaning and collecting you would be short. There can be significant grinds that are trapped between the burrs outer dia and the wall of the grinder. Thus the only way to clean is to have the burs rotate and use good vacuum and or compressed air.... HOWEVER you would then need to add extra beans to the first grind OR you will be short in the dose... Simple method, run a half shot through the grinder and collect into a container... Over time you can sell these grinds to the neighbour or re pack some pods and still get good results. OR You keep them and use to re condition / flush your machine after a chemical clean.
