Kevohere wrote:
Don't know if you have got into the "P" and "I" settings yet, but; I found the "Proportional" value by pressing and holding the Shift and Function key (2nd from left) for 3 secs, then the "Set" key twice brought up the "P" setting. Mine is set at 36 but on the instruction sheet, the default(?) shows 25. Pressing "Set" again gets "I" (Integral Time) with mine set at 80 and the instruction manual shows 150. Keep pressing "Set" to get out of the menu. What's your view on these settings (36 & 80) and what is yours set at? Cheers. :coffee2:
Hi Kevin, no I can't get P and I...I wonder if mine has be locked out by a setting. Sorry to be a pain but are you able to cycle through all your individual settings and note them down for me? I'll go into mine and load those settings in and maybe it will allow me to access the P and I. If you could do this the next time you access your roaster I would be eternally grateful!
