Trooper Yes very impressive, I am like a little kid with a new toy, I can't stop looking at it. Thanks for your valued information today derrilex. What was that brand of halogen cooker again thanks. :question:
Koffee_Kosmo Gouly wrote: Yes very impressive, I am like a little kid with a new toy, I can't stop looking at it. Thanks for your valued information today derrilex. What was that brand of halogen cooker again thanks. :question: Not sure if you will find this brand Highlander You can also get well priced Turbo ovens at - Homeart Aldi Online from various vendors They are mostly halogen and shine a light on the roast when it cycles on KK
Koffee_Kosmo I have started another KKTO build & Bean Cooler for an enthusiast Today I completed the cooler I used a 13 lt bucket as the HELLER brand exhaust fan fitted snugly Holes drilled for exhaust and opposite the power cord entry [attachimg=1] I used a wash basin and cut the bottom out for the sift unit to fit into it [attachimg=2] The fully assembled unit [attachimg=3] During the build I will post photos as it's happening as there will be a few small changes with the base and I will make a wire type agitator KK
eggbert Where's the sift unit from KK, and what is it made out of? Looks a bit plasticy - is it alright with beans in contact at 200C+ temps? Cheers.
Koffee_Kosmo eggbert wrote: Where's the sift unit from KK, and what is it made out of? Looks a bit plasticy - is it alright with beans in contact at 200C+ temps? Cheers. All from bunnings The perforated section is a hard plastic seed or soil sift I an pretty sure it will be OK for heat and if not the design lends itself to interchange just about any metal colander type if required KK
eggbert Thanks. Might get around to sorting my bean cooler out again one day and it is always good to get inspiration from successful projects here
Koffee_Kosmo eggbert wrote: Thanks. Might get around to sorting my bean cooler out again one day and it is always good to get inspiration from successful projects here With that in mind I have given the new owner two options By inserting a stainless steel ring and using the left over colander insert from the pot set I came up with this [attachimg=1] [attachimg=2] KK
lukemc KK Where did you find the pot set? I've been looking for one on and off since last year to get into a KKTO. is there any chance your making them to order again 😉
Koffee_Kosmo lukemc wrote: KK Where did you find the pot set? I've been looking for one on and off since last year to get into a KKTO. is there any chance your making them to order again 😉 Yes I have enough parts to make a few more This pot set was supplied by the owner However they come up from time to time on Gumtree and eBay I will post photos of the next build just completed later tonight KK
lukemc I'll keep scouring and if I find a set I'll get in the begging line to convince you to build one 🙂
Trooper I found the following sieve on E Bay: 1/8 Inch Mesh Classifier sieve for Gold Prospecting, Mining, Panning, was a bit expensive but works really good. .
Koffee_Kosmo This second build differs a little cosmetically to Gouly's roaster although the aim is still the same I used a solid piece of Acacial wood ( no glue ) that was formally a chopping board in another life And I manufactured a wire type double agitator blade & more streamlined auto centre metal stays [attachimg=1] [attachimg=2] [attachimg=3] KK
Koffee_Kosmo Gouly just came over to show off his roast and do a roast while here under my watchful eye Also to show off his cooler and cooling sieve Took a couple of snap shots for the members Fantastic roast Gouly [attachimg=1] [attachimg=2] [attachimg=3] KK
lukemc Looks great 🙂 if anyone sees a set of the arcosteel pots for sale please feel free to Let me know 🙂 KK Would any 24cm pasta set work or do they need to be exact specs?
Koffee_Kosmo lukemc wrote: Looks great 🙂 if anyone sees a set of the arcosteel pots for sale please feel free to Let me know 🙂 KK Would any 24cm pasta set work or do they need to be exact specs? The preferred ones are the Arcosteel set They are made with thicker steel If you chose another set get 240mm dia and be certain that the handles are spot welded not riveted And the insert not to deep KK
