Dear Coffee lovers,
I'm in the process of converting fellow work colleagues to users of espresso coffee machines as distinct from those ugly/dirty poor capsule,in this attempt I'll need some support from some of you good people.
I've done some careful research on the habits of these users of capsule "coffee" machines and I believe with a little guided democracy I may make some headway.
These capsule machines seem to be marketed as "quick" coffee makers when compared to espresso machines using per-ground or freshly ground coffee beans.
I have sourced a reasonable number of machines (Sunbeam/Breville) 52/53mm group head size not the commercial size,I've also seen filter baskets made specifically for the ESE (easy serve espresso) coffee pods that come in a size (52/53mm)however,for the life of me I cannot locate a source for these ese baskets.
This is where with your collective wisdom,I need assistance.....anyone know where I can get them?
My hope is to lure capsule machine users away with an alternative quick coffee maker using ese pods with their eventual move to pre ground or freshly ground beans.
I have moved some of these machines to people after demonstrating how much better tasting and quick and easy coffee pods really are,those people have freely moved onto coffee bean use as a direct consequence of ese pods.
Please check your contacts and sources and reply so I can move forward,where do I look next?
Helpful advice is always welcome.
Regards
Mick
