When it comes to espresso repeatability is the key. So when establishing a grind and dose only change one variable at a time and take notes. Don't change both grind level and dose at the same time, when your reasonably happy with the dose weight (use scales if you desire, it certainly helps in the early stages) start to vary the grind, coarser or finer until you reach a point where you are only fine tuning.
