OK. Here's a pic for Lovey. This is looking down under the warming tray with the plastic guard that's usually there removed:
Notice the fairly square hole towards the bottom-right of the panel? I suspect the metal tab inside there is some sort of catch that releases the whole top shell of the case ... if only I knew how! For Koffee Kosmo: Yes, they're fresh. No, they're dark (I like STRONG coffee!) - but not oily. And, sure, it's a burr grinder. Does any superauto have spinning blades??? Who would buy such a thing? It's actually a pretty clever mechanism with a vertical drop from the grinder into the brew cylinder so there are no stale grounds. But it just isn't fine enough. The finest setting is about the same fineness as is right for a drip-filter and that's way too course for espresso. Back to the panel. 🙂
