askthe coffeeguy wrote:
Ive got a sunbeam cafe series grinder and a Mazzer Super Jolly at home - though I find myself mainly using the Sunbeam due to space constraints - and I must say that when its dialed in and working properly I cant taste the difference between the two
Crikey .. MASSIVE CALL! .. and I like it. 😛 Do you really need to spend the big $$ to get a machine that adequately suits your needs? According to the coffeeguy .. that would clearly be a no. The Breville Smart Grinder, from what I have read around the traps .. is a pretty good little unit. It should be good enough up to a Coffee Machine of a certain high value. Personally, and I'm no expert by a long shot <--- lol .. but, if I were in Sue's position, I'd only be upgrading my Grinder when also upgrading my Coffee machine. For example. If the Coffee machine was around $2,000 .. I'd pay $600 for a Grinder (Compak Push or Macap M2D) M2D weren't available in Aus in Dec 2013. I was going to import one .. only ended up with a Compak Touch that I purchased locally. I prefer to dose manually .. so I would've been happy with the cheaper 'Push' model.. as it turned out. My guess is that if you have a Coffee Machine under $1,000 .. the Smart Grinder should be good enough *I don't have the experience that the others have in here.. nor have I used a range of different equipment.
