Moon wrote:
Crikey .. MASSIVE CALL! .. and I like it. 😛 Do you really need to spend the big $$ to get a machine that adequately suits your needs? According to the coffeeguy .. that would clearly be a no. The Breville Smart Grinder, from what I have read around the traps .. is a pretty good little unit. It should be good enough up to a Coffee Machine of a certain high value. Personally, and I'm no expert by a long shot <--- lol .. but, if I were in Sue's position, I'd only be upgrading my Grinder when also upgrading my Coffee machine. For example. If the Coffee machine was around $2,000 .. I'd pay $600 for a Grinder (Compak Push or Macap M2D) M2D weren't available in Aus in Dec 2013. I was going to import one .. only ended up with a Compak Touch that I purchased locally. I prefer to dose manually .. so I would've been happy with the cheaper 'Push' model.. as it turned out. My guess is that if you have a Coffee Machine under $1,000 .. the Smart Grinder should be good enough *I don't have the experience that the others have in here.. nor have I used a range of different equipment.
Don't get me wrong, the Smart Grinder is a good grinder, I think. I did notice it struggling with a medium roasted coffee I had, slightly labouring and slipping clutch. I'm not sure if that means it will struggle with all medium to lightly roasted beans or is it was more to do with the type of bean. There will be no more machine upgrades for this little black duck for a bit :angel:. I have nothing to compare it to either, only the spice grinder I was using before the Breville ;D.
