You can go by weight , For a double 1-2 ratio 18g ground coffee = 36g in the cup Timing can be anywhere from 25-35sec from hitting the switch, I use a 20g basket and find 30-35g out is good ,this is into one cup, not split, If you can place a cup on some small digital scales and tare just before you hit the switch.
