Its definitely a tricky coffee to roast. I have no direct experience with behmor other than what I have seen / read of it. My gut tells me the direct radiant heat will not suit this bean very well. I am tending to stay away from Brazils these days as I find them very finicky to roast close to my liking, challenging is good, but for me the result is not worth it. I find Kenyans to be challenging to roast, but with much more exciting results. Anyway FWIW, in small solid drum, QuestM3 I settled on a very gentle long roast 16 to 17min. No application of heat at start, gentle application of heat till yellow, then steadily decline until about 45sec to a minute after first crack ended = 2 or 3 degrees rise in temp from end of first crack temp. Overall % of roast time from first crack to finish was around 21%, so quite a gentle finish, medium looking roast. Long dry, long ramp and stretched first crack. How would one achieve this on Behmore ??? Dragging out the roast for extended periods after the end of first crack is a great way to kill Brazil beans, especially if they experience a rise in temperature ROR. Another way to look at it, if you wanted a darker roast say just starting second crack. You want to get to first crack a bit faster, so that there there is more of a difference between the inner and outer bean allowing a longer time to be spent between start of first crack and second without killing it. To achieve this with sensitive beans I would use the lowest power setting profile possible (to avoid scorching the precious ) and play with reducing batch size to get acceptable roast times. Which means you can achieve faster roast times but at low environment temps. Sometimes roasting = :tearhair:
