Dry bean. wrote:
Not bad, splitting may be a bit too much heat between first and second crack. How long to first crack and how long between FC and when you stop the roast?
Now I need to think because I have just been writing down the time on the timer...FC was at around 8 and a half minutes, 2nd crack was around 2 and a half minutes later. I hit cool just after 2nd crack started. My notes aren't what they should be, I am trying to juggle watching, writing and absorbing what is going on all at once 😛.
askthe coffeeguy wrote:
I've got two Plus machines side by side, and I couldn't be happier with the roast quality I only ever use manual mode now but the presets are a great way to get started I keep a constant eye on my roasts but still almost miss the shutoff timer sometimes. I also consantly moniter the internal temperature as I don't like my roasts running hotter than 140C, and indeed if the afterburner runs too hot (around 200C) it can shut the whole unit down I usually pull the roast at the first audible snips of 2nd crack, as it tends to come our a bit light otherwise, though the trick here is to be 'coadting' temperature wise or at least not running too hot when you hit thus stage, so that you don't keep pushing the roast during the cooling cycle Plus I usually keep the door open on the cool down cycle as it drops the temperature twice as fast I live the temperature and the consistency with this roaster and as far as I'm concerned the quality is on par with a commercial roaster ! All the best with your new toy ! Pat
Crickey Pat, I'm struggling with just one ^-^. I have been concentrating on learning the presets for now but as I have no idea what a hard bean is, what a soft bean is, what is high grown and what is low grown, I have been using P1 and saying a couple of Hail Marys. I found a post on another forum where the poster posted what setting he uses for different beans so I am hoping that might help me a bit. I'll try one of them next time anyway. I have read about opening the door during cooling. Do you think it is worth a try? Thanks again 🙂.
