Moon wrote:
Hi ... you may not be able to share your thoughts and experiences on the new machine that hasn't come out yet ... but .. you CAN share your thoughts on the performance of the Zarre ... which is a machine you DO have. Let's talk about Coffee ... You first
Thank you Mr. Moon. I am using the Zarre from early last year and I am enjoying this machine, it has 2 vibration pumps with double boilers and it has 3 PID(grouphead, steam boiler, hot water boiler) also which I liked most. There are 2 modes(2 settable auto modes and 1 manual mode) to extract espresso, I can set pre-infusion from auto modes also and can adjust the extraction pressure by manual mode(there is a knob on Zarre's controller). and the grouphead is their own designed grouphead which installed dual heaters and PID for temperature stability. I think this machine is enough to use at home as I do.
