The Yirgs came out okay, did three batches, the first two 350g1lbP2A, the third at 350g1lbP3C. With the first two my aim was to pull the first one about a minute and a half after the end of FC, and the second batch a minute after it to see which I preferred. The only thing is the second batch everything happened a bit sooner (30s roughly): 1st batch FC/Rolling FC: 13/13:15 2nd batch FC/Rolling FC: 12:30/12:45 1st batch end of FC: 14:40 2nd batch end of FC: 14:10 Was wondering if anyone had any advice with something, obviously this time I was wanting to pull the roasts at different times, but if I was wanting to get consistent roasts and get that second roast to the exact same depth (and moisture loss) as the first, what could I do? Even if I pulled both roasts a minute after the end of FC, they wouldn't be the same would they, because the roasts happened at different speeds... ? I don't have any temp probe, but if that's probably the best way to measure it I may have to consider that hehe Thanks in advance 🙂
