Okee-dokee! It has officially been a full year that I've had the 270Wi, so thought I'd post a little somethin'! Ever since I started using it, I have loved every second of it. No major issues whatsoever, the only thing I can comment on is there has been the odd time when a dose has been a bit out. The most happened the other day, and it dosed a full gram less than the preset. That was the only time that happened, the other times were at max 0.5g out. This off dosing probably constituted 2% of my usage of it through the year. The other times were super accurate. And I reckon at times it could be attributed to the little amount stuck up in the chute gaps. So it grinds for a certain time based on the weight it's getting, but perhaps a tad bit stuck in that space falls in (when over) or gets caught (when under). I've never worried when it goes under, as you can easily use the burst mode to top it up. Still find altering the grind really simple and straight forward. Still haven't found a one setting/height with the portafilter holder fork so that I can use my spouted and naked. You can swivel the black rubber holders to adjust height as well, but it's either too high or too low for switching between both. Not really that big a deal, as I don't switch them rapidly, but usually when I'm dialing in a new bean I'll start with the naked to see how extraction goes, whether any alterations are needed, then when I've got that nailed I'll switch to the spouted, and just adjust the fork accordingly. I've done the bluetooth update every two months, even when I don't think it has any updates available haha, but it may just give it a nice reset. So that's it! One year on and still functioning awesomely. Grind quality is still exceptional, still as loud as an elephant haha but it doesn't last long how fast it grinds.
