Hi guys, I've got a Diadema 'Junior' which is still making a noise but not pumping through any water...
Now those of you who know me will realise that unlike most of you, I have absolutely no technical expertise (remember my background was from publishing!).
I rang Cosmorex in Canberra (I'm based in Adelaide) and they said they could ship me a new pump, but it also 'could be the capacitor'. Have taken the lid off (even that stretched my technical capabilities 😃 ) and a friend of mine with a meter said it's actually a solenoid coil not a capacitor, but still seems to be holding charge ok (.97)... so presume the pump is stuffed, except if it's still making a noise, could it be something else - for instance I haven't descaled for ever ???
Problem is, I don't know any good repairers in Adelaide; do I buy a new pump from Cosmorex and get them to ship over (around $250) in the hope that I can fit it myself & this will fix things, or do I need to bite the bullet and start investigating couriers from ADL to Canberra and back?
The problem is that it's obviously pretty heavy, so if there was any way I could fix it myself that would be great but as I mentioned, I'm not the most technically competent of people!!
All and any thoughts/ideas much appreciated!
pic attached
