Firstly, what makes a good coffee ?
In my opinion (and that is the good thing about opinions, they are neither right nor wrong), the answer to this is purely subjective.
I'm sure that some will have a list of criteria to which they will refer, and tick off accordingly. Me, I'm of the opinion that if I don't like the flavour, the aroma, the texture, the temperature....then it is not a good coffee for me.
I'm more interested in making a coffe that I like, rather than acquiring a taste for a coffee that I have made.
I have had an el-cheapo Sunbeam machine for 3-4 years and with this, I have produced cappuccinos that have made me very, very, happy.
Warning to all purists. You may not like what you are about to read so continue at your own peril.
1). The cappuccino must be hot (not warm, not cool)
2). The froth and general body of the cappuccino must be creamy (not watery and not fluffy like candy floss)
3). The coffee flavour must not overpower the taste of the froth (this is the point that will most likely cause the purists to choke on their "la-de-dars".....sorry, I can't spell "latte").
I am now the proud owner of a Sunbeam EM6900 (that's ok...I probably don't like your choice in cars). Again, some may still consider this to be an "el-cheapo" machine, but those of us who take delight in buying the kids that "new pair of sox they always wanted", will consider it a Ford Falcon as opposed to a Hyundai Excel.
With this new beast, I now appear to have the ability to create "crema", as was discussed at length on a previous post. Unfortunately, this now appears to be causing me some angst in relation to requirements 1 & 3 that I nominated above. So (if you're still with me), let's look at them in greater detail.
1). The cappuccino must be hot.
I have always poured boiling water into my cups to prepare them prior to making the cappucino. I have always used my hand as a temperature guage on the side of the milk jug to determine how hot the milk is. (If skin from your hand remains on the side of the jug...you may have made it too hot).
With the new machine, the final cappuccino is not as hot as with my old machine. Since my cup preparation and frothing of the milk technique has not changed, the only remaining variable is the espresso component. I believe that my earlier machine used steam pressure and the new one uses pump pressure....I'm open to correction on this.
Can this change in espresso method cause a significant change in final temperature ?
(Yes....this is where you can jump in an offer opinions)
2). Frothing of the milk.
Different machine which is just going to take a little getting used to before I produce the froth that I am after.
3). Coffee flavour permeating throughout the froth.
*Putting on flack jacket here*
As we go to the trouble of sprinkling a little layer of chocolate on the froth of a cappuccino, I like to be able to scoop a little of the froth with my spoon and not be over-powered by the coffee flavour. The coffee flavour will get it's chance when I take a good swig from the cup. You can usually tell when it's going to taste like coffee because of the colour of the froth. Don't get me wrong, I'm not looking for virgin white, but I don't want mustard coloured froth either. I suspect that this is due to the "crema" that is produced during the espresso stage.
Yes ? No ?
In summary, my cappuccinos are no longer hot enough (even the wife agrees with this and would like me to solve the problem), and the flavour has changed somewhat (possibly due to this new phenomenon called "crema").
This whole thread was initiated because someone asked me what I thought of my new machine and was I making "better" coffee.
Unfortunately, I am yet to decide on the answer.
