Tamping - A gentle guide (kind of) - page 3 - How to improve your coffee - Coffee Forum
Please login or register.
Bezzera
Author Topic: Tamping - A gentle guide (kind of)  (Read 26715 times)
Kelsey
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • Third wave. Heh.
« Reply #50 on: 16/07/2012, 07:42 PM »
Oooh interesting!
I've always been pedantic about wiping out with a dry cloth... time to try something different!
LONDINIUM I, Compak E10.
Full disclosure: I have commercial arrangements with Bezzera (AU) and Londinium Espresso. I am not required to market them on this forum & any opinions expressed are my own.
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #51 on: 16/07/2012, 08:00 PM »
Better try it out. I'm a wiper
RichardM
  • Java Veteran
  • Gender: Male
« Reply #52 on: 16/07/2012, 08:18 PM »
I do the unholy "wipe out stray grinds with my finger".
Bezzera Mitica, Mazzer Super Jolly, Behmor 1600, Pullman Deluxe Tamper
Ronin
  • Senior Barista
  • Gender: Male
« Reply #53 on: 16/07/2012, 08:32 PM »
my hypothesis for this is that it lines the basket with a fine film of moisture, 'trapping' the grinds and leading to a finer extraction.
Or perhaps it just liberates a little heat from the sides of the basket providing a 'sticky' surface for the coffee that comes into contact with it - again leading to a tighter extraction
Thoughts anyone?
Interesting.
Perhaps the moisture traps and swells the coffee on the outside puck, but not the inside has something to do with it also.
Happiness is not a destination
It is a way of life
and a good coffee of course
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #54 on: 18/07/2012, 08:50 PM »
Tried the damp basket approach. Was getting a bit of spray action on the naked then went the wet basket and no more spray ? Who knows, could have just arsed it. One less process though so I might stick to wet wipe/no dry - because its sooooo time consuming to dry the basket  :D
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #55 on: 21/07/2012, 12:02 PM »
Awesome AM - out with the 2 mm shim then :D :D
lemoo
  • Barista
  • Need more coffee
« Reply #56 on: 21/07/2012, 12:32 PM »
i've never actually tried that before to see how much space is between the puck and shower screen
what would the best way to determine that space be?
5c test with rice?
Rocket Giotto PP V2 : Macap M4D : BCG800 : Presso : Yama Cold Drip : CCD : OE Lido : Hario Skerton : VST Ridgeless : EP Ridgeless : Pullman Nexus : Behmor 1600 : ACF Cups
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #57 on: 21/07/2012, 12:38 PM »
Just use coffee IMO :thumb:
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #58 on: 21/07/2012, 02:32 PM »
I also use a convex tamper
Although both a flat and convex profile tamper face give good results, I find the convex to give better head space when the PF is locked in
KK
C-man
  • Old Coffee Fella
  • Gender: Male
  • no such thing as great coffe, only a great cup
« Reply #59 on: 21/07/2012, 05:49 PM »
why do blonds like tilt steering?
Better head space..
Rancillio S24  HG one bench grinder Rosco mini- Hand grinder,  Presso,  modded popper
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #60 on: 21/07/2012, 06:50 PM »
Ok here is one for discussion. Ive just measured the distance from my seal to the edge of the screen. Its 9 mm. However, the screen is a bit odd in its construction. It has a lip of SS about 2.5 mm wide and the screen itself is concave in shape (deeper in the centre). Its a two part deal, behind the screen is hefty chunk of brass that comes off with the screen which is then separated and cleaned etc.... So my question is, where do you take the measurement from ? The centre ( deepest part of the screen ) or the out lip ? If its the outer lip I'll have to drop the basket level 11 mm down from the top which isn't going to leave much in the basket. There is a good 1.5-2 mm difference from outside to the centre. So a fait imprint of the outer ring is probably fine ? What do you reckon ?
Dry bean.
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • Bezerra Galatea - Mazzer Mini - La Pavoni Lever
« Reply #61 on: 21/07/2012, 07:09 PM »
I'm in the no contact between puck and screen school so would do the 5 cent test under the centre screw. :)
Cheers,
Dry Bean.
Old age and treachery always overcomes youth and skill. (Willie Nelson)
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #62 on: 21/07/2012, 07:27 PM »
I did that a few weeks ago DB and dropped my dose, a lot. I now have it where I get a slight imprint of the outer ring of the screen. I'm pretty happy with the results but interested in what others think too.
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #63 on: 22/07/2012, 09:13 AM »
Remind me mate, are you using a naked?  If the shot looks good with a naked and the puck looks good then I think you've cracked it.  Do you want to borrow a VST?  They are completely transparent in regards to all these issues (to the point of being a PITA) as you saw at my place.
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #64 on: 22/07/2012, 10:58 AM »
I have a naked ( thanks to AM) but rarely use it. Diagnostics only :D. As for the VST, Well,  :-X :-X. But I should try a bigger basket just for fun eh
Kelsey
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • Third wave. Heh.
« Reply #65 on: 22/07/2012, 11:21 AM »
I'm thinking of getting a VST basket off Greg while he has them on special.
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #66 on: 22/07/2012, 11:56 AM »
I can give you a triple basket but its ridged
Now if your tamper fits in it it yours
KK
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #67 on: 22/07/2012, 01:00 PM »
Sweet KK :thumb:
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #68 on: 22/07/2012, 02:45 PM »
I grabbed a second when they went on special so that when I do multiples I can work two portafilters.  Great value while they are on special.  I couldn't live without mine!!
Go on DX grab one... You know you want too!  ;)
Kelsey
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • Third wave. Heh.
« Reply #69 on: 22/07/2012, 02:50 PM »
What size did you get?
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #70 on: 22/07/2012, 02:51 PM »
18g and I had Greg check that my tamper would fit.  Great service!
Kelsey
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • Third wave. Heh.
« Reply #71 on: 22/07/2012, 02:53 PM »
That's one reason why I want one, because I know he!ll keep the measurement of it on file until I get a tamper.
CoffeeParts
Related Topics
Last post 21/11/2007, 03:43 PM
by gregpullman
Last post 21/11/2011, 10:57 PM
by Kelsey
Last post 17/09/2013, 10:19 AM
by askthe coffeeguy
Last post 28/11/2013, 02:18 PM
by C-man
Last post 08/12/2015, 03:06 PM
by Brett H
SMF spam blocked by CleanTalk
coffee
