Please login or register.
Coffee Curators
Author Topic: Project Cosmic  (Read 51188 times)
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #125 on: 16/11/2014, 08:03 PM »
Electrics chased in, started  insulation and first few lining boards.   ;D
Hope to have the walls finished by the end of the week.
Chester
Apprentice Coffee Roaster
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #126 on: 20/11/2014, 10:57 PM »
SilverStreak goes up on the dark walls then the rest will look like this. Slow going dragging sheets around in  the heat and still recovering from the surgery. I know, harden up and get it done!!   :)
[attach=1]
contrasting walls
C.
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #127 on: 21/11/2014, 09:27 PM »
Looks great!  Insulation??
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #128 on: 21/11/2014, 10:27 PM »
Yes Brett H eco wool 1.5 throughout.
C-man
  • Old Coffee Fella
  • Gender: Male
  • no such thing as great coffe, only a great cup
Project Cosmic
« Reply #129 on: 22/11/2014, 09:18 PM »
that is a good look with the expressed joints
what kind of sheets are they?
Rancillio S24  HG one bench grinder Rosco mini- Hand grinder,  Presso,  modded popper
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #130 on: 22/11/2014, 09:31 PM »
12mm veneered ply with a 18mmx18mm gloss black enamelled strip. (hate using enamel)
Walls are now all insulated and most of the sheets on the wall, tomorrow will knock that side on the head  :thumb:.  Then it's time to scrub the concrete ready to prime and seal.
Getting closer.
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #131 on: 23/11/2014, 07:34 PM »
Starting to look something now. Can see the light at the end of the tunnel  :thumb:
[attach=1]
[attach=2]
C
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #132 on: 23/11/2014, 08:50 PM »
Looking terrific mate!
C-man
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #133 on: 24/11/2014, 07:55 AM »
I never expected it to be so nice when you were talking metal shed,
what will you do with the ceiling?
Kevohere
  • Senior Barista
  • Gender: Male
  • Hi I am (not so) new here
Project Cosmic
« Reply #134 on: 24/11/2014, 06:14 PM »
Attach it to the roof bearers I suspect.
LM GS3; Caravel; Macap M7D; BNZ MD74; AeroPress; Hario Pourover and WDC-6 cold drip: Royal Balancing Syphon; and several hand grinders. 1kg JYR Roaster.
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #135 on: 24/11/2014, 08:56 PM »
That's a good place to start me thinks  :laugh:
Still tossing ideas around but polycarbonate coro sheets in white are looking like a nice option, just screw straight to the existing bearers, no need to batten it out. Slide in the eco wool as I go, job done.
Need to earn some coin before that will happen though  :(
C.
borat123
  • Java Veteran
  • Gender: Male
Project Cosmic
« Reply #136 on: 25/11/2014, 04:20 PM »
Looking good!
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #137 on: 04/12/2014, 01:03 AM »
OK so walls are all finished, electrics in, waters ready to go once the cabinets are in and tomorrow I am going to seal the floors with a vision of moving the SilverStreak across on Saturday then fit the gas and fluing.  Sunday, cabinets and then the big lift to bring the bowling alley bench top into place. Everything is moving along nicely and all going to plan everything should be up and running by next week.
[attach=1]
 :thumb:
Chester
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #138 on: 04/12/2014, 02:46 PM »
First coat of clear gloss down  :thumb:  another couple of hours and I will be able to do the top coat.
[attach=1][attach=2][attach=3]
Remind myself to put a mask on for the second coat  :-[
Chester
Kevohere
  • Senior Barista
  • Gender: Male
Project Cosmic
« Reply #139 on: 04/12/2014, 03:26 PM »
Chester
That WOULD be a good idea :exclaim:
Don't want to have those coffee tasting buds getting damaged.  ???
That floor and the shed is coming along very nicely Chester. Well done.
"It's beginning to look lot like Christmas" for the 'Streak' to be underway in its new home.
Any thoughts on a special inaugural blend for the occasion?  :thumb:
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #140 on: 06/12/2014, 04:28 PM »
Hmmm much too wet to move the SilverStreak into her new home  :'( .  Oh well see what tomorrow brings, guess I will have to console myself with some Nekisse/Slayer shots  ;D.
Chester
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #141 on: 07/12/2014, 08:21 PM »
Moved the SilverStreak into her new home and she looks amazing sitting there. Finish the fluing tomorrow then it's time to start on moving the Slayer  :thumb:   Everything will be up and running by next weekend.
Chester
C-man
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #142 on: 08/12/2014, 08:21 AM »
Looks  good Chester, what did you use?  2 pac?
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #143 on: 08/12/2014, 08:32 PM »
Got the hole cut in the roof and the fluing fitted and siliconed, an hour later was hit with a major storm  ---  NO Leaks  :thumb:
Going to be a coffee free zone as of tomorrow for a few days  :'(, maybe I better have a morning coffee then disconnect the Slayer.
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #144 on: 09/12/2014, 09:59 PM »
Slayer disconnected, benches moved into roastery, all electrics finished, SilverStreak 100% operational.  :thumb:
Tomorrow morning have to go and collect the bowling alley bench top (it's crazy heavy) Think by Saturday I will be able to sit back and enjoy the coffee's of my labour.
Chester
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #145 on: 09/12/2014, 10:22 PM »
So... Pictures?? LOL ;)
This is so exciting mate, we're all living vicariously through you and as an aside from a home roaster:
I've bought beans from MyCuppa recently and LOVED THEM
I've bought beans from Supreme Roasters today and them
I read about your journey so there must surely be a time soon when we'll all be adding you to our let's buy from list so that we live, grow and learn.
All power to you mate and keep us posted!
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #146 on: 09/12/2014, 11:24 PM »
Thanks BrettH for the kind sentiment, I really look forward to getting it all finished now, as it is so close to done.  I also hope that not to far after Christmas I can host an open roastery weekend and all those that are close enough can come check out the roastery, play on the Slayer, bring some green along and roast a batch on the SilverStreak and let me thank them for the support and inspiration I have personally received from being a member of this forum.
First forum member I met was KK, helped me improve my milk technique on my  Bezzera, wow how things have progressed since then, has been a great and exciting journey and it's almost time to turn it up another notch  ;D
I will try and take some almost finished photos tomorrow.
Chester
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
Project Cosmic
« Reply #147 on: 10/12/2014, 10:13 AM »
Good on you mate.  I reckon there's a few of us that owe the great KK a debt of gratitude for his knowledge and inspiration!
Lacehim
  • Old Coffee Fella
  • Gender: Male
  • NS Oscar|BSG|KKTO
Project Cosmic
« Reply #148 on: 10/12/2014, 03:31 PM »
Chester
It's certainly good to receive and give back to the community eh. :)
I've been loving your coffee via C-Man so it would be great to put a face to the name/beans!  It's all looking fantastic.
cosmic_couple22
  • Senior Barista
  • wanna be roaster
Project Cosmic
« Reply #149 on: 10/12/2014, 08:08 PM »
Put the bowling alley bench top in place today and moved the Slayer across.
So as promised a few almost finished photos.
[attachimg=1]
Plumbing in the Slayer
[attachimg=2]
On the bench
[attachimg=3]
Front view
[attachimg=4]
Roaster
Tomorrow will see the water filtration connected and the slayer up and running, a few final tweaks, bring in some stools and benches, finally have a clean up. Tomorrow night will be ready to do the first roast in the new setup and pull some shots on the Slayer.  Still have to pave outside but think I might have a couple of days just to enjoy the new roastery.
Chester
Bezzera
Related Topics
Last post 22/11/2012, 07:59 PM
by derrilex
Last post 25/03/2012, 08:57 PM
by UNM
Last post 24/04/2014, 09:05 AM
by eggbert
Last post 18/08/2012, 08:52 PM
by Brett H
Last post 12/01/2015, 09:21 AM
by Brett H
