I'm building a KKTO for a member - page 2 - Roasters - Different Roasting Equipment - Coffee Forum
Please login or register.
Coffee Curators
Author Topic: I'm building a KKTO for a member  (Read 24833 times)
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #25 on: 08/07/2014, 04:52 PM »
I have started another KKTO build & Bean Cooler for an enthusiast
Today I completed the cooler
I used a 13 lt bucket as the HELLER brand exhaust fan fitted snugly
Holes drilled for exhaust and opposite the power cord entry
[attachimg=1]
I used a wash basin and cut the bottom out for the sift unit to fit into it
[attachimg=2]
The fully assembled unit
[attachimg=3]
During the build I will post photos as it's happening as there will be a few small changes with the base and I will make a wire type agitator
KK
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #26 on: 09/07/2014, 06:53 AM »
Same bucket and fan as mine KK ?
eggbert
  • Barista
« Reply #27 on: 09/07/2014, 01:56 PM »
Where's the sift unit from KK, and what is it made out of?
Looks a bit plasticy - is it alright with beans in contact at 200C+ temps?
Cheers.
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #28 on: 09/07/2014, 04:59 PM »
Cheers.
All from bunnings
The perforated section is a hard plastic seed or soil sift
I an pretty sure it will be OK for heat and if not the design lends itself to interchange just about any metal colander type if required
KK
eggbert
  • Barista
« Reply #29 on: 09/07/2014, 10:02 PM »
Thanks. Might get around to sorting my bean cooler out again one day and it is always good to get inspiration from successful projects here
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #30 on: 12/07/2014, 05:16 PM »
With that in mind I have given the new owner two options
By inserting a stainless steel ring and using the left over colander insert from the pot set I came up with this
[attachimg=1]
[attachimg=2]
KK
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #31 on: 12/07/2014, 05:18 PM »
KK Where did you find the pot set? I've been looking for one on and off since last year to get into a KKTO. is there any chance your making them to order again ;)
Alex Duetto II, Compak K3, Rocky Doserless, Gaggia Classic w/PID - Backup/Holiday machine
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #32 on: 12/07/2014, 05:24 PM »
Yes I have enough parts to make a few more
This pot set was supplied by the owner
However they come up from time to time on Gumtree and eBay
I will post photos of the next build just completed later tonight
KK
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #33 on: 12/07/2014, 05:26 PM »
I'll keep scouring and if I find a set I'll get in the begging line to convince you to build one :)
Gouly
  • Junior Barista
  • Hi I am new here
« Reply #34 on: 12/07/2014, 06:25 PM »
I found the following sieve on E Bay: 1/8 Inch Mesh Classifier sieve for Gold Prospecting, Mining, Panning, was a bit expensive but works really good.
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #35 on: 12/07/2014, 07:27 PM »
This second build differs a little cosmetically to Gouly's roaster although the aim is still the same
I used a solid piece of Acacial wood ( no glue ) that was formally a chopping board in another life
And I manufactured a wire type double agitator blade & more streamlined auto centre metal stays
[attachimg=1]
[attachimg=2]
[attachimg=3]
KK
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #36 on: 12/07/2014, 07:30 PM »
The wire agitator and the self centre lugs
[attachimg=1]
[attachimg=2]
Gouly
  • Junior Barista
  • Hi I am new here
« Reply #37 on: 12/07/2014, 07:51 PM »
Nice job as normal KK, the wooden base looks terrific.
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #38 on: 12/07/2014, 07:55 PM »
Looks great!
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #39 on: 15/07/2014, 01:14 PM »
Gouly just came over to show off his roast and do a roast while here under my watchful eye
Also to show off his cooler and cooling sieve
Took a couple of snap shots for the members
Fantastic roast Gouly
[attachimg=1]  [attachimg=2]  [attachimg=3]
KK
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #40 on: 15/07/2014, 01:16 PM »
Looks great :) if anyone sees a set of the arcosteel pots for sale please feel free to Let me know :) KK Would any 24cm pasta set work or do they need to be exact specs?
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #41 on: 15/07/2014, 01:24 PM »
The preferred ones are the Arcosteel set
They are made with thicker steel
If you chose another set get 240mm dia and be certain that the handles are spot welded not riveted
And the insert not to deep
KK
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #42 on: 15/07/2014, 01:25 PM »
I'll keep working on it! They are like hens teeth to me!!!!!
derrilex
  • Old Coffee Fella
  • Gender: Male
« Reply #43 on: 15/07/2014, 01:29 PM »
KK
Looks the business. Nice one  :thumb:
Gouly
  • Junior Barista
  • Hi I am new here
« Reply #44 on: 20/07/2014, 07:02 PM »
I have purchased a brand new Acosteel pasta 24cm set up from Ebay and look like I have a second hand one.
I will pass them onto any-one interested in building a KKTO. I know they are as rare as hens teeth, so I was very lucky to find them. :)
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #45 on: 20/07/2014, 08:55 PM »
Gouly - I'm interested please :) do you mind sending me a pm with cost etc I'm happy with either second hand or new
Naki^chap
  • Junior Barista
  • Gender: Male
« Reply #46 on: 20/07/2014, 10:13 PM »
Great thread,
 I`m looking at building a KKTO type roaster,I have collected a few bits and pieces so far,
How much gap should there be between the bottom of the insert and the pot or false floor ?
I have a couple of pots that are different depths and my insert fits them both.
Rancilio S26 , La peppina , siphon , CCD , Moka pot , Ibrik ,
Compak K10 WBC , Pharos#480 , Baratza preciso , Corretto.
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #47 on: 20/07/2014, 11:08 PM »
Great thread,
Thanks for the question
When calculating the false floor plate depth fitting distance
Aim for a roast chamber total volume for both pots and including the Turbo Oven dome of between 7 and 9 litres
However in noting the technical aspect of volume one only needs as little as 10 mm distance from the bottom of the perforated insert to the false floor plate
KK
lukemc
  • Barista
  • Gender: Male
  • Hi I am new here
« Reply #48 on: 21/07/2014, 08:31 PM »
Hi Gouly - I've replied to your PMs. :)
JackH
  • Instant Drinker
  • Gender: Male
  • Hi I am new here
« Reply #49 on: 13/08/2014, 11:27 PM »
Excellent build KK! I see many new ideas here to add to my KKTO style roaster. The KKTO design is proven and works very reliably.
--Jack
BeanRoasters
Related Topics
Last post 16/01/2008, 06:45 PM
by psaigh
Last post 14/12/2010, 01:09 PM
by askthe coffeeguy
Last post 04/09/2012, 09:51 PM
by Brett H
Last post 24/02/2016, 07:30 PM
by Brett H
Last post 28/06/2018, 06:51 PM
by K_Bean_Coffee
SMF spam blocked by CleanTalk
