I noticed on another thread a comment that this bean needs a significantly finer grind than many others. My experience has been the exact opposite. My grinder has numbered grind adjustments from 1(coarse) to 20 (fine). I normally grind somewhere between 16.5 and 17.5 for espresso and 3 for cold process in the plunger. My first shot of the yirg was at 16 and it pulled a 35 sec double ristretto. To get an espresso, I had to go back to 13, same as gunna limu.
Mind you, the ristretto was REALLY nice. Espresso ok, french press of this one didn't do it for me. Roast was 16min 50sec, 40 sec after first snaps 2nd crack, but only 2degree rise over that time, so not rolling. On the other scale, a cs10.
What have others experienced with this bean? I' ve only tried a couple of ethiopians, and this is one I think I like. Next time a light roast and see what is different.
