Black residue in the steam wand
Hi Everyone.
I've had this leaky wand for a while, and I pulled the tap off to take a look, and turned the seal around to see if that helps it seal. Didn't work. The wand has started to get really hot when the machine is left on. It's a cool touch wand so this isn't normal.
Jack said it might be some milk that's been sucked up inside, so I pulled it all apart. I put a cotton bud own inside the fitting that is attached the machine (with the tap off), and there is some black residue there, and it was also evident in the plastic tub inside the wand. Is this caused by milk or something else? The steam has been quiet watery since I got the machine, and I purge the wand post steaming the milk. Now and again I haven't done it instantly when distracted by kids and stuff.
The water in the boiler is clean... I'm just not sure what's causing the issue here. The seal is very basic, just a bit of rubber that pushed against the inlet to stop the flow. I find it hard to believe that milk would get up inside the valve when it's closed, so how would this gunk get in there?
HELP!
