David Gubbin wrote:
Couple of points. Firstly, hi. ....... Lastly, we'll not be promoting "no heat up time". The "bling" of a actively heated group head was not designed as bling. We simply laid down a super tight performance tolerance to the designers, so the AHGH, was deemed just as important as pid's, non-thermoblocketc etc, in achieving those tolerances. .... Dual SS Boilers
Hi 🙂 I didn't mean to offend with the "bling" side of things. I was more just making a point of concern about the extra electronics being integrated into a machine that is essentially putting as much heat out as a small fan heater. I'd love to hear more about the internal layout of the machine, and how the electronics is shielded from the heat. SS Boilers seem like an adequate compromise over brass for a cost, and, while not a negative in any way towards Breville, will still provide a differentiation between this machine and the more expensive dual boilers (ie Expobar) and the Italian HX machines.
