Ok here is one for discussion. Ive just measured the distance from my seal to the edge of the screen. Its 9 mm. However, the screen is a bit odd in its construction. It has a lip of SS about 2.5 mm wide and the screen itself is concave in shape (deeper in the centre). Its a two part deal, behind the screen is hefty chunk of brass that comes off with the screen which is then separated and cleaned etc.... So my question is, where do you take the measurement from ? The centre ( deepest part of the screen ) or the out lip ? If its the outer lip I'll have to drop the basket level 11 mm down from the top which isn't going to leave much in the basket. There is a good 1.5-2 mm difference from outside to the centre. So a fait imprint of the outer ring is probably fine ? What do you reckon ?
