No water flow through the group: Breville BES900
[color=rgb(51, 51, 51)]No water flow through the group on the BES900 ?
Breville have had some issues with o-rings as used for the main coffee solenoid as in flow and dump path.
The symptoms are "No water flow through the group" or a "loss of flow through the group "
As I understand it they have tried a number of batches of o-rings and in an effort to put the problem to rest for once and all. They have decided to go with a new gasket that covers off on the whole mounting face of the coffee solenoid.
This effects all models and depending on any number of other variables may or may not be evident, but it is a known problem.
I am aware that some have had to have their machine in 3 times already and with any luck; the latest fix will solve this particular issue.
[/color]
