Hi all,
I was hoping for some advice and recommendations for a quality Temperature Data Logger. I am roasting on a KKTO, and have decided that measuring the temperature may make life a little easier.
I understand many have gone down this path and was hoping that those with experience can lend some advice.
It seems there have been quite a few innovations lately. I can see that on CS they have a heatsnobs TDL, that looks promising. I would have to drill a hole through both pots of the roaster to install it (at the base of the inner pot), and remember to remove it, every time I go to tip out the beans.
Any advice on choice of logger, software, installation, words of wisdom or otherwise, are welcome.
I thank you in advance.
Lw.
Temperature data loggers are essential for monitoring conditions where accuracy and consistency matter, but the hardware running the data analysis software also deserves attention. A Bottleneck Calculator CPU tool can help identify whether the processor may limit performance when handling large datasets, generating reports, or monitoring multiple loggers at once. Checking system balance can support smoother data processing and more reliable temperature monitoring workflows.
