Barista training Melbourne
Hi Everyone,
I've just stumbled across your site and was pleasantly surprised with what I found!
I've been a keen coffee drinker for some time now, and used to think I was a bit of a connoisseur! A little investigation into doing a barista course soon put that thought to rest. I currently use a very basic sunbeam machine at home and some of the time it manages to produce a reasonable espresso.
I live in the Melbourne area and only work part-time and would like to investigate being a barista. Either way I'd love to do a course.
Does anyone have any suggestions?
I've seen a little bit about Justin Metcalf (cafe learning) who seems to be attached to the Sydney based Toby's Estate- but can't find too much info on him. Also the William Anglis Institute seemed to offer a pretty thorough course.
Anyway if anyone had any advice that'd be great.
Thanks in advance! :)
  • Hi attard and welcome to the forums. I'm sydney based so i have only a very limited knowledge of melbourne training places but check out these: Veneziano http://www.venezianocoffee.com.au/ 22 Bond Street, Abbotsford T: 61 3 9421 5585 AASCA recommends: William Angliss Coffee Academy http://coffee.angliss.vic.edu.au/overview.htm William Angliss Institute of TAFE 555 La Trobe Steet Phone: (03) 9606 2111 Cafe Learning www.cafelearning.com.au (though site not found?)
  • Hi Tommy, Thanks for the welcome and info! Is there anyone who's done any of these courses? Or have any further info on the 'Cafe Learning'? Cheers, James
  • Never heard of cafe learning, but the other two are highly recommended. I suggest that you go along and have a look for yourself, especially at Veneziano - where you can sit down and have a coffee, and have a chat to the guys there at the same time. Cheers, Pat
  • Hi Attard .....just read you query .......... A couple of courses worth a try ........Home Barista Institute on Victoria street near the Melb Market . Check the website at homebaristainstitute.com.au   ........covers the basics fairly well over 3 hours and then a more advanced latte art . Both are pretty good , but try to cover a lot of ground in 3 hours . A more thorough option is Chris Natoli at William Angliss . I started with Victoria Street as it covered the field quickly and gives you a good feel for those areas where you need better attention ......a good grounding before William Angliss . In between times I practised my thing off on the Giotto and Mazza Mini Hope that helps ... Regards, Coffeebean
    Run by Justin Metcalf. Knows his stuff - knows lots about coffee - you couldn't get a better teacher.
  • Thanks everyone for the advice, plenty of great suggestions! I think going in to visit a few places sounds like a good starting point. Once again very happy to have found this site, although I have probably spent far too much time on here in such a short time! Cheers, James
  • Hi James - just like to re-iterate what flp said above - Justin Metcalfe at Cafe Learning, is a World Barista Judge and probably the best around. -A
  • Hi all, I've finally found some info on Justin Metcalf, if anyone else was interested, log onto: www.justinmetcalf.com cheers, James
  • James If you can organise some training with Justin, it would be well recommended. I am not sure what Veneziano are doing with regards to training, but if you can get a session with Dave then it would be worth the expense. If you get to Sydney let us know. John
  • seems as if David makin is also running training too.
  • Hi fattylate, Thanks for the advice, do you know where I can find David? I've just returned from overseas and I'm ready to start some training and Justin Metcalf is unvailable for 3 weeks, so if DAvid is also recommended I'll give him a try to. Cheers, James
  • Try Veneziano Coffee. Works for them. Let me know how it goes. I will be looking at sharpening some off my own skills and ironing out any kinks.
