Looks like So Good are trying to get into the coffee scene the way Vitasoy did with its "Vitasoy Cafe".
So I bought some yesterday to give it a go.
I got it for $2.19, on special. Normally $2.69, putting it right next to Vitasoy original.
Unlike the other soymilk from So Good this one is made from whole soybeans not the "soy protein isolate". Good start!
Only 8% though, Vitasoy 17%, Bonsoy 14%.
Doesn't seem to be much filler and rubbish in it too.
Tasting out of the box cold it was a bit thin. Watery with a sweet chalk taste. Not very pleasant. It had a very strong drying effect on the insides of my mouth, a bit like tannin but closer to, I guess, talcum powder. Vitasoy has this effect too but no where near the same strength.
So how does it texture, "easy frothing blend" as claimed? Not bad, pretty good actually.
The end result is very white compared to Bonsoy or Vitasoy. Too white, like white chalk.
It bleeds more then Vitasoy or Boysoy in latte art and the white looks wrong to me.
Doesn't do well when heated more then it should over (over 55-60, although the package says 60-65 for best results). The white looks ever more white and the soy separates a lot. While all soymilk doesn't like to be over heated this one seemed to hit a point and turn really bad.
Latte art and texturing is only a small thing. How does it taste?
Horrid. Really bad.
Like crushed chalk mixed with low grade white sugar and lots of water. The chalk taste comes out more and more the higher the temperature. Really bad on it's own and worse with coffee.
Avoid.
For use only on pesky, preaching, self righteous vegans.
