:rofl:
Yep, all the rain and after all the work on the roof... The seal around the firplace flue has decided to crack and let water dribble in and down the flue.
1: Trying to plug from under neath, does not work as there are layers of flashing :tearhair:
2: Water dripping slowly down and on to fireplace, is not observed by old blind ment that keep spending time down stairs trying to see if chat works :stir
3: Water sitting on a old solid combustion stove causes lots of oxidation :pan
4: Don't toss the nearest towel on it and then think about the fact that it was a white towel; after the fact :mad:
5: What is the best sealant that can be applied to a very wet surface and still adhear and set ?
Now, chat would have given me the answer in a couple of minutes...
