Bezzera Strega HX Lever Machine - Custom Mods.
2
  • KK, I'm 95% sure it's ironbark with a slight chance of Sydney bluegum. I'll pm the house address and some demo photos when I get back in town
  • on 1329741892:
    :rofl: any wonder you find it easy to use  :angel:
    Unfortunately, it's the same thought that crossed my mind when I first saw it........perhaps this post needs a PG rating as it contains suggestive content.
  • on 1329785284:
    I would be happy to remove the photos if they appear to give another or different  perception KK
  • Isn't coffee something rarely enjoyed by anyone young enough to require 'parental guidance'? I'm not sure there's a heck of a lot to be worried about.
  • KK - just hangin it on ya.......they are fine mate and of course........very beautiful.
  • on 1329866066:
    So KK... After a few pulls of the lever ... Are you happy with it ? If so I will look at progressing the other bits AND just leave them at a finish that will allow you do do what you want to them.
    Re Lever pull handle It is perfect AM You wont believe how comfortable and easy it is - its as if it was made for my hand It requires less upper body effort to actuate the lever - its practically effortless On both the upswing and downswing I have no hint of any slippage, although on the original handle the slippage was mostly perceived Its also the perfect length Re Other handles Cant wait - dont make then to skinny And dont forget "my favourite"  bit the copper ends (its a mechanical engineering link to my past)
    on 1329868535:
    Howwllll
    You can say that again KK
  • You da man AM  :thumb: You know that I am ever so grateful for putting in the time that you have
    NOTE: Every item has a flaw or two BUT the user is aware and it is such things; that make this a truly ONE OFF.
    Beauty is in the eye of the beholder mate Perfection if its attainable follows the same  set of guidelines They are (Beauty Is In The Eye Of The Beholder) KK
  • Thanks for everything AM  :thumb: I was out mowing the grass Will post photos when I get them, and post progress & process reports during the finishing stage PM sent back KK
  • Just picked up the handles Note they are unfinished and after I took these photos They were placed in a full immersion bath of water based penetrating sealer The sealer was watered down with some boiling water to help the process Will leave in the bath for several hours or overnight - will check progress regularly and decide More photos to come as it happens These photos are of the raw timber handles KK
  • Guys, they are absolutely amazing.  What a phenomenal job AM.  I would love to pimp my BFC but the steam and water knobs look very tricky.
  • on 1331378846:
    KK has come and left with bits of rough cut wood, that were kindly donated by the D:    :thumb:    (Chippes only ever get a Letter for a name  :rofl: ) So after his treatment and a few days to get it all dry etc. I expect to see a new looking machine  ;D
    Rough cut - used a 40 tooth blade doing that. You want rough I'll use a 80 next time, or a beaver  :rofl: :rofl: :rofl: They should look sweet when sealed up KK
  • Update Yes I know its quick since the last one  :angel: More photos These are photos of the handles in a bath of thin mixed sealer Looks like they are having a milk bath (just like Cleopatra) but rest assured it dries clear  ;) KK
  • Mmmmm milky goodness  :thumb:
  • An update once again The handles soaked for 24 hours in the watered down sealer and then dried naturally in the sun AM had a hard time turning this timber as it shattered while being turned on the lathe. The timber was so old (over 100 years) You will notice some of these stress cracks on the photos below & the sealer soak has bound all the timber This treatment has made them light, strong and shatter proof The next stage was to sand lightly One unexpected consequence is that after the treatment the timber has lost its light red appearance and reverted to a wonderful walnut colour I have experimented with applying a natural red dye to one small handle and sanded it to see what it would look like I will also experiment with a blue & yellow dye at a later stage to see if I can create a unique finish I have taken some photos for you to see Large handles sanded ready to apply sealer or experiment  >:D The small steam/water knobs are 1 = Natural with a line of top coat 1 = Red dye sanded & a line of top coat With and without flash What looks best ? KK
  • Wow that interesting. The wife likes the brown and I tend to agree but both are tops. Cant wait to see the large ones
  • It's too hard to choose KK.  They both look great.  :thumb:  Wonderful handles!  AM is a craftsman, he just doesn't give himself enough credit! Can't wait to see them on the machine!  8)
  • Update This is a photo of the half finished handle Its had approx 20 very thin coats of sealer with a soft fine sand very 5 coats The red tape is there to protect the copper ferule The coats will continue to be applied, until I see a 3D or deep luster look even if it takes 100 coats to do it KK
  • Yes AM I had more cracks appear and it was a chore to fill each one as they surfaced At one stage if not acted upon quickly I may have lost a chunk (especially the right hand one) The camera & flash however does bring out features that to the naked eye are not that dramatic Only time will tell as for now they are holding together Its not your fault its the timber I am passing a timber merchant tomorrow and may stop in to see if they have anything unique KK
  • Agree, not so kind under the flash
  • Reference shots of Camphor Laurel; treated with patented nano tech petrifying penetrant scaled.php?server=521&filename=camphorlaurel01small.jpg&res=medium scaled.php?server=26&filename=camphorlaurel02.jpg&res=medium scaled.php?server=404&filename=camphorlaurel03.jpg&res=medium
  • Lovely patina 3rd Crack!
  • Wow! I want that as a group handle!
  • KK What's the 'sealer' that you're using. Perhaps it's actually causing the cracks by soaking the handles in it - sucking the oils out perhaps. I'm not sure what look you're going for, but a lightly oiled finish would allow a nice wear patina to build over time. Maybe something to think about for next time though. There's also a number of finishes that can be applied on the lathe itself, and you'll get that super gloss that I think you might be chasing.
  • on 1331809569:
    The cracks were there - at the start, during turning and after finishing As the handles were exposed to the atmosphere (prior to applying sealer) they started to show stress fractures The sealer is a water based sealer I use in my job when I seal timber floors ect - and it halted this self destruction after a soaking bath Then I proceeded to seal the larger cracks over and over until they were filled and level with the timber Then I sanded the handles all even Applied 20 fine coats with a sand every 5 coats Note these coats are very fine as the sealer is of water consistency and cant be put on thick as its self levelling on floor surfaces and is quick dry @ approx 20 min KK
  • Sounds like you know what youre doing. Ive got some Eee, i can give you enough for a handle if you want to try it for the next one you make. Applied on the lathe. http://www.ubeaut.com.au/eee.htm
  • Derrilex kindly dropped off some more timber to be used as handles & knobs He thinks its  - Sydney Blue Gum Or another that species I forgot what he said  :doh: Here are a couple of photos taken on the IPad AM you know I hate to impose - But I was told that you love this more than your real job  ;) KK
  • Slight correction on timber type. I'm pretty sure its spotty gum but a slight chance of blackbutt also. Very heavy for the size of the blanks with a nice tight grain. See what happens. Release the wolf.
  • Some pics of KK's timber. I'm really struggling to get a confirmed ID, but looking at images on the net it appears either spotty gum, turpentine, string bark or blackbutt - all of which were readily available in QLD at the time that the donor house was built.
