Exporbar Minore pressure drop
edited November 2012 in Espresso Machines
Have been having dropping pressure on the brew gauge for a while & got to the point where max I could get adjusting the opv was 8 bar, which wouldn't be a problem except the coffee was crap.
Initial thoughts was dying pump, but only 2.5 years.
AM in his kindness leant me a spare pump to try. Thank you Mr Management.
As it turns out it was not the pump and I spent some time chasing the problem.
Turns out the spring in the opv had compressed to the poing where it was too short, bottoming out the valve = not working properly. Took it to work and stretched the spring, set it to 10 bar blanked off so it should be close on the machine. Worked a treat. Machine now working like a new one and coffee tasting great thanks to some tasty Indo from Jeff at My Cuppa.
I serviced the group head while I had it apart, and checked for scale, not much at all & was surprised. Great learning expierence and happy to have fixed it myself with no expence but time. Good to know how it goes together too
  • Wow, that's commitment!  I think most of us would have had to buy a new OPV! I do love tinkering though, and find out how things work.  Sometimes I just don't have the tools to fix things.
  • It's actually pretty easy with small springs. On this opv was just removal of the circlip, wind out the adjustable screw, remove the spring, physically stretch it ( I used 2 flat head screwdrivers in the spring, then elbow grease  :thumb:), replace screw and test. I could test it on an oxygen bottle at work tho, I didn't need to replace it to get the pressure close. I just needed to stretch it far enough to get enough adjustment around the correct pressure.
