I had an early VAM/Caravel that was pretty rough and not really worthy of a restoration, i played around with the idea of converting it to gas for a camping setup, but luckily thought I would try chucking a saucepan of boiling water in the kettle and dropping the thermocouple from my PID on my kitchen Caravel into it to see what temp it settled at.
To my surprise it settled at 90deg which is damn near spot on for pulling shots from the Caravel anyway!
I found that by warming the kettle first with a bit of hot water it settled at a couple of degrees warmer which gave time to pull a couple of shots in a row before getting too cool.
So I pulled all the electrics out of it, swapped in an aftermarket drip tray to salvage a good one for another machine, the element ended up in a restorer that had a blown one and I ended up with the perfect camping accessory!
Paired with the Lido its a fairly compact and robust setup for travelling and or camping.
I cant see why the same wouldnt work with other similar kettle style manual levers.
