Cunill Tranquilo Issues....
I am using the above grinder (doserless) in a small commercial outlet which is my first venture. I have encountered some issues with the grinder in that when I do a run of coffees and have to pull a number of doses in succession, the grind slowly deteriorates and the grind size becomes larger. It would appear that under pressure, there appears to be some internal expansion which is affecting grind quality. I am currently putting about 4 kg a week through it, however that tends to be concentrated at certain times throughout the day.....is this a fault of the grinder or is it just not built for such volumes?
