A question if I may please. I'm using 2 different sized Bodum units. The small approximately 875ml and the large approximately 1273ml. The smaller Bodum is 69% smaller in volume. I roast my own beans and I have the timing down so that I get a good quality brew. However, I find that the timing may be different between the 2 sizes. The extraction is obviously different. Does anyone know what the extraction rate is for different volumes of water? I had assumed that because the differences in Bodum size would allow the same extraction rate for the given differences in volume. However, when I use the same timing for both brews, there is a definite difference in quality if I use the same timing. Any help would be greatly appreciated.
