Hot Water/Steam unit (old)
Cleaning out the garage!
Anyone want this thing?
I don't know if it works, I have never turned it on. Measures 32 ohm across the active/neutral pins, so chances are the element (1800W?) is ok.
There is no pump or auto fill. You have to do that yourself from the front tap.
Pickup in Warburton or Dandenong south. Might be able to drop it off in Melbourne somewhere.
No takers by next weekend the pressurestat will pulled out and rest thrown out.
Cheers
This discussion has been closed.
