ESPRESSO MACHINE WATER QUALITY
Recently, I have, either, had a number of conversations with industry persons or have heard industry persons talk about the quality of the "feed water" going into the espresso machine.
Water quality and the importance of such appears to be grossly misunderstood throughout the industry. Actually to a point of ignorance.
I know of new espresso machines 2-3 years old that basically need to be scrapped because of inadequate filtration.
It certainly is a concern to find out that many equipment suppliers do not understand the importance of the correct filtration system to suit the area where the espresso machine is to be installed. Believe me all areas are different.
For example:
Joe espresso machine company sells a machine to:
Joes cafe on the Gold Coast
Joanes cafe in Townsville
Joeys cafe in Sydney
JoJos cafe back of Bourke, etc, etc
It is recommended to put a filter on the water supply. They all do.
However, for example JoJos (Bourke) is running of 'tank water'. They think the water is sweet and clean and only neeeds a sediment filter!
Right or wrong?
In other scenarios what use is a carbon filter??? Could be useless except for the removal of organics.
Then the other issue is why have a filter system if you don't service it.
OK FORUM Maybe an interesting topic.
Would be interested in any thoughts
JD
