Sunbeam EM4800 w/ stiff operating dial
I have a Sunbeam EM4800 - had it for a while and can get reasonable results.
The "operating dial" (the main control - front and centre) has become stiffer and stiffer. Finally got so stiff that I stripped the machine down to investigate. It turns out that the dial rotates some ceramic disks to switch the hot water between the coffee and steam outlets (I guess that this is very similar to the workings of a mixer tap). These disks seem to be coated in some sort of grease - presumably acting as a seal, and maybe as a lubricant. This coating is very viscous causing the stiffness. The disks themselves seem to be in good condition - no obvious scratches or lime scale.
The obvious solution to my problem is to remove the old coating and replace it. I guess removing it will be relatively easy. The big question is what to replace it with? Presumably it needs to be high temperature, and food-safe.
Google "research" has got me nowhere yet.
Am I on the right track?
Any gotchas or hints?
