Will rainwater wreck my new machine
I just purchased my first coffee machine - an Expobar Pulser with a water filter in the supply tank. The salesman advised against using my readily available rainwater supply unless it was filtered.
Does anyone have any thoughts on this. If a filter is required, what is recommended & can it simply screw onto the rainwater tank tap.
Thanks,
Dave
