Help with froth setting???
Hi,
I just purchased a Krups Orchestro Dialog (FNF2) and the manual is somewhat confusing when refering to the amount of froth it can make!
Please see the link to the manual online
http://www.krups.ca/krups/pdfs/FNF2.pdf
On page 7, In step 1 the last 2 images say that you should turn the valve to 12 o'clock and wait till the residual water runs out then press again one the steam escapes.
Then on the same page, step 3 says to turn the valve to 9 o'clock for more froth or 12 o'clock for less froth.
What i am unclear about is why you need to do step 1?\
Thanks.
