I was wondering how you would tart up that little area KK. Looks great! :thumb:
Thanks Lacehim It needed to flow and blend from the adjoining section Now I will probably make some more of those timber steps to follow it up the fence line so it blends in seamlessly KK
The final build update Finishing touches to the Safety Glass Pool Fence Finishing the side skirt build with access panel A big thank you goes out to the Carpenter Alex from Ringtail Carpentry He is a specialist deck builder that did the most over engineered small deck build, with excellent work and is highly recommended Attachment not found.Attachment not found.Attachment not found.Attachment not found.
Alex's work is breathtaking! Even more galling is that I assume he built it all with awkward hips, joins and spans with consummate ease!?!? What a star and what an amazing job! Many relieving and relaxing dips KK!
Please note The lights can be ON or OFF Set up as one colour of several to chose from or revolving Dimmed or bright Suitable for all age groups or occasions KK
