Quiet grinders
The purchase of a quiet coffee machine gets me thinking about a quiet grinder.  Are the Compak Silent range much chop?  Is there any other competition?  (What sort of motors do the titan conicals run - can I slow them down somehow?)
  • My Pharos is delightfully quiet... That's if you ignore the gnashing of beans against burr, but that's inevitable, I suppose... And somehow very satisfying... Now, the aroma... That gets the juices flowing...
  • I have a Compak a8 that is advertised as low-noise but it's still 1-2 decibels louder than my Rocky.  Rocky still makes noise as all grinders will unless there are specialised burrs fitted that are acoustically dampened... Teflon or some rubbish from memory.  I don't think they were adopted, it was an idea I read many years ago on another site. I ran a DB meter on all my grinders and Rocky is the quietest.  It's still not silent and neither are any of the compaks but there may be one I didn't try that is a bit better than Rocky.
  • Compak had (they may still have) a K6 and a K8 available in a "silent" model. Not sure, but I think the K6 silent is no longer available locally. We have a few of these K6/K8 silents and the non-silent's out in cafes from the good-ol FOL legacy days. I can tell you there is a noticeable difference in the noise between the silent and non-silent. Whilst it was not easy to pick the difference in a side-by-side comparison in our factory, the true test was when I changed silent for non-silent (and vice-versa) in a client cafe setting whilst we serviced the burrs and cleaned up the unit off-site before returning it the following week. The loudest noise came from the cafe owners............give me back my quieter grinder..........or I want to keep this new grinder, it's great. I also have an A8 on the kitchen bench at home - but it's not a silent model (not sure how many of the A8 silents are around). It's not too bad noise-wise and because it's quite fast, the noise is only for a short time. Obviously, the larger the grinder, the shorter the noise duration but then you run into retention issues. I cannot vouch for other model/types of grinders by comparison, other than to say our fleet of numerous commercial Macap's are really tough, but also very, very noisy compared to the Compaks. Using a doser adds to the noise levels (although home users do not tend to buy dosers). I also think Compak's are slightly quieter than their equivalent Mazzer, but I have no technical or field facts to back that claim up other than my personal assessment. Happy to be told otherwise. Grump's suggestion of a modern, high-end hand-grinder is the best solution for a home use situation - noise, grinds retention, cup quality, etc.
  • The BNZ conical I use is fairly quiet A lot quieter than all my previous grinders KK
  • My Rocky is almost totally silent,..just a faint "wirring" hum.....until you put beans in. ! I suspect many grinders are the same. It is not the motor / mechanism that makes the noise, its the way individual grinders "amplify" the actual grinding sounds that make the difference. I suspect that the hopper is acting like a loudspeaker as it is directly mounted on the upper burr carrier , so i have been planning a serious modification ! ;) Anybody noticed if their Mazzers or similar are any quieter with the hopper removed ?
  • K6 silent is still available, as is the Wega equivalent (6.4 silent) - but it is only available in doser which I dislike.  Can't buy a high end hand grinder for love or money right now - no stock of either pharos or HG One.
  • on 1394317670:
    The production on the pharos has slowed down , you need to check each day for in stock .
  • Should not be a problem getting an HG one, only took 4 days  to get here just need lots of coin....
  • HG One is out of stock for another two weeks at least...
  • Interesting.... Be prepared for a long time to season the burrs if you get the TIN coated ones. Other than that, it is a good grinder.
  • Tin is a soft semi precious metal that is used to rustproof other metals Tin is also food safe - hence it's use in steel food cans coated in tin KK
  • I think he meant Ti coated
  • or rather, TiN - titanium nitride - which gives a particular gold colour you can sometimes see on drill bits.  Good for cutting surfaces.
  • Yep,  titanium nitride PVD (physical vapor deposition) in layman terms is a food grade barrier metal applied to a surface for purposes of hardening and protection. It is commonly used on cutting elements where edge retention and corrosion resistance are desired, and will extend the lifetime of a cutting part three to five times. I can't decide yet if it was a good Idea or not, being almost beach-front I need all the corrosion protection I can get, But seasoning them is a long slow process....
  • on 1394441387:
    There is PVD and then there is PVD and not all PVD is the same... Good quality drills as used in most machine shops are not; yet you will see many a set in Burnings but am sure many are just cheep plating. Quality PVD is an interesting process and as to food safe..... Not unlike the term ORGANIC OR  GF;  in the large majority of cases it is nothing more than clever marketing and people making assumptions and drawing long bows. I am happy with the placebo effect, but when some charge significant $$$ and know full well the product is only good for the placebo, that is questionable. As to a Quite Grinder, they are all noise generators; and without a barrier to trap the noise they can not change the physics involved and thus  E=MC2  still holds true. Cheapest is a set of disposable ear plugs  :rofl:
  • so true, I have used many a cheap drill bit with gold coating that we crap
  • on 1394490979:
    My good quality set (Suttons) are not plated, merely HSS.  The lathe interchangeable cutting surfaces are, though.
    I can't get earplugs for the dog - who likes to bark at both the vibe pump (getting a rotary pump machine), steam wand (drink black coffee), and grinder (what can I do?)
  • on 1395083574:
    Drill bits can , and are , resharpened.  modern lathe tool bits are disposable... (probably TiN coated Tgn Carbide) No point in coating a drill if the coating is going to get removed during sharpening, whilst the coating on the disposable tool bit will extend it life considerably
    on 1395083574:
    I can't get earplugs for the dog -  (what can I do?)
