No. 75 mm flat burrs. http://www.espressomechanics.com.au/_literature_37187/F75E I considered bidding for one of the 71EK Conicals, but I specifically wanted a large flat burr grinder rather than a conical in the belief that the higher rpm of the burrs and sweepers helps to reduce the retained grinds that you have to accept with the large conical commercial grinders. As it appears that this m/c retains about 5 gms total, which is not to bad, and I have yet to remove the anti static comb across the discharge port.
That's funny... I have an 83mm flat burr Compak that retains more than the K10 Conical. ...
If you are referring to the A8 auto doser, then yes, that m/c has a reputation for retention due to its particular dosing system. How much do you estimate your K10 hangs on to ?
Between 2 and 3. Everytime i do a clean I do a weigh in and weigh out to stay a member of the OCD club. I brush the chute clean every dose... If I didn't it would retain most of Em
