Not sure how important the false pressure thing is? have been doing it each time I use it, easy to do, just open the steam valve, dump steam for a few seconds, wait for pressure to build again and go. Pic looks good, you did a good job with clean up.
I made sure to remember to do it last cuppa. I'm not sure it made a difference though. Maybe it did and I didn't notice. Thanks, it looks a little inferior compared to yours lol. I'm, struggling to get 30ml in one pull of the lever. Any ideas?
on 1458355444:
Brilliant folks! Great pictures of great fun machines! Many happy shots to you both!!
The machine is 4-5 years old. The seals were supposedly replaced, it then made a few coffees and then it was put away in favour of the old owner using a bigger machine. Make of that what you will but the seller did not come across to me as being dishonest. I spoke with him quite a bit. Hubby says it looks like it hadn't been used for quite a while. We do have a seal kit for it but instructions on how to do it.
I did leave it up a bit longer this time Brett, it helped. It turns out the machine had been is storage for 2 years. It came with a complete gasket kit so hubby will see it right in the next couple of weeks.
Here's a little trick that works, have not seen it mentioned anywhere else. One of the things I missed on the Pav was the lack of a cup warmer, was having to warm the cup under the hot water tap For a single cappuccino size cup, place your cup upside down on the boiler cap of the machine before you turn the power on, an espresso cup sits nicely on top of the lever pivot point, by the time the machine is up to temperature the cup is well and truly warm and ready to go, love it. ;D
Brilliant, I have been using the milk frother to heat it up 8).
Has your other half had a chance to check it out yet Sue?
Update on the LaPavoni. On another thread I made the comment that the in the cup experience of the Pav was inferior to my Bezzera. Bearing in mind that my drink of choice nowadays is a Lungo and that's what I've been making on the Pav up to now, that is approx 90 mls in 30 seconds, 3 x pulls on the lever, I stand by my remark as far as this type of coffee is concerned, the Bezzera is streets ahead. However, last night, for the first time since owning the little lever I felt the desire for a straight espresso, so 16 grams in the double basket, 30 second pull, 30 mls, the resultant shot was excellent, just as good as, in fact perhaps better than the Bezzera, so it seems the La Pavoni's forte is straight espresso or perhaps milk based coffee I'm impressed. :thumb:
A very honest and believable set of comments DB......bravo ! Would also not be surprised to hear that some coffees work better on one type of equipment compared to another, or that fresher coffees work best with the shot dynamics of one system versus another, or that over time one of the systems gives your palate a superior experience or offers a more reliably consistent outcome in the cup. I sometimes discover that just when I'm about to "write off" a coffee, or a blend, or a roast profile, a grinder, a set of filter baskets, a tamper, a dosing approach, a belief system around resting and degas periods. a brew temperature setting.........the impossible happens............a last minute Cinderella story......blown away by a god-shot that throws my theory and the kitchen sink out the window. When it comes to coffee and espresso extraction......you can never know for sure......
Nice! They're an easy machine to work on but seriously, I don't need a hobby-fixer-upper....I need a coffee!!!
Exacery :D. Hubby decided he's rather leave it to the experts and I think he is looking for an excuse to check the place out. I'm just a tad concerned about what we may come home with :/.
