The Bezzera Strega Thread - The Witch!
Deals done - The Witch is landing in Werribee after all. :thumb:
KK - I read that you use a convex tamper .. I've always liked the idea of a convex tamp .. the thinking being (rightfully or wrongly) that having a rise of grinds around the outside wall of grinds in the basket would offset the tendency for the water to hit the wall and favour the the weakest resistance .. which would be the gap between the grinds and the wall.
Which tamper is it, where did you get it, and how much did it cost? They appear to be fairly scarce, and one was around $120. Of course, the flat ones would be easier and therefore cheaper to turn in a lathe... although you'd think it would only take a slight 15 second adjustment.
What basket do you use .. and what size is it? I have a 58mm from a previous machine that I will use initially .. which will be a huge improvement on the plastic one I was using that came with the PV Lusso.
Nothing urgent ... just curious.
