Hi All, Just a clarification point on the Brita C150 Bypass setting for the coffee machine. Recommended by-pass setting = ? % My statistics are: Total dissolved solids mg/L: 100 – 136 pH: 7.8 – 8.0 Total hardness mg CaCO3 /L: 48 – 62 Calcium hardness mg CaCO3 /L: 30 – 39 Magnesium hardness mg CaCO3 /L: 18 – 25 Alkalinity mg CaCO3 /L: 29 - 39 Just curious on the bypass table that i should be setting this based off the Calcium Hardness which is between 30-39. Does that mean the bypass setting should be between 30%-39% on the bypass setting on brita filter? Thanks in advanced.
