Thanks for those answers. ^-^ I already have a van with plumbed sinks(hot and cold), electricity is all wired and certified by a licenced electrician, 15amp with an inlet (for coffee machine) and four 10amp double power points that will draw power from another inlet. I was asking about the gas set up because I am trying to get out of using a large generator, my capital has been depleted by unexpected expenses ( I had to have the whole thing rewired) and I still have so much to obtain. I want to be able to set up in a paddock somewhere, if I am asked to do so, but that will require an independent power supply and I do not want to spend $6000 on a generator. With the two inlets I thought I may be able to use two smaller generators instead of the bigger more expensive unit, but if gas will help me to make the power supply dilemma easier, I am willing to consider it. As for the coffee machine plumbing/water filtration, I am looking for any suggestions that will help me to get the right equipment. For example a water pump to move the water from the tank to the coffee machine. Does anyone know where I can find that sort of information, and please don't say Google because I need more than a "spider" search engine can give me. Once again any recommendations of reliable information sources, would be greatly appreciated. Thanks to all DizzBean.
Spending $6K on a generator is probably about right. If you start looking for cheaper and inferior solutions be prepared to take the risks of failures or interruptions.....and worse the impact upon reputation. Before long the difference between the $4K and $6K generator are about the takings at just a single large event. If there is one item that needs to be the best.....it's the generator. Getting a gig at a good event is not easy these days. There can be long standing commitments in place with existing suppliers and the absolute 1st option is always going to be given to previous suppliers that had performed well. If something happens and you have to shutdown during the event, you still have to pay all your fees and the organizers are unlikely to invite or allow you back next time. You should also be prepared to compete - often there are multiple outlets offering coffee at big events where a good crowd is expected. Space is a premium on any mobile setup. Having multiple energy sources means carrying sufficient fuel for each. A coffee machine tech, marine/caravan provider or plumber will be able to help you with water pump solutions. Most of these are typically systems used on boats or caravans to move water and many are small and reliable DC powered systems that can run from either transformers or batteries. It's simple stuff but you need to have everything in place first so the solution can be designed with the correct fittings and parts, e.g. dimensions, bends, taps, etc. Most of these pumps are tough little units that can run dry for short periods without damaging the pump. If you don't want to use google, then go and visit a BCF store or a specialize marine supplier and ask for help.
Hi there, Ive been missing in action for a bit - work was hard to find and I had to travel far and wide and then I hit a depression ( me of all people - bigger than most and never been scared of anything ) - it was a humbling experience. Anyway the mists have cleared and Im back into coffee - when I last visited there was an active forum where we could chat online in realtime ? I dont see the option here?? Let me know please would love to catch up on a social somewhere. Cheers, Springbok
Hi Springbok, welcome back; sorry to hear you haven't been well; actually I'm guessing you're talking about the chat box, but you're right we've removed that. Just out of interest, where are you based - in SA or over here in Aus.?
Welcome back Springbok I remember that you always brought the Bilton at the QLD coffee meetings And I roasted some beans for anyone that wanted me to We have all been busy In fact so busy that this is my first post in a while Reason I am posting now is that I pulled my back out and I'm lying down KK
Thanks guys - Im back in Brisbane - 2015/16 was spent in Whyalla with Onesteel - then they went into administration - then on to Sydney till Feb 17 and Ive been back here since then. Cheers,
welcome back! yeah its been a bit quiet recently but we're still al kicking around! I just got back from a 2 day coffee catering gig making coffee for a tennis tournament with my own setup - loved it, be happy to do that again! Pat
Siblings can have a surprisingly strong influence on how a person develops, from learning patience and sharing to handling disagreements and supporting each other through difficult moments. I sometimes find that siblings quotes capture these everyday experiences in a simple way, especially the mix of teasing, rivalry, loyalty, and affection that exists between brothers and sisters. Much like learning espresso, relationships are built through experience, small adjustments, and plenty of patience. A good reminder is that even when siblings disagree, keeping respect and understanding at the center can make the relationship stronger over time.
