Hi all Minore ii, iii users etc.
I have a gut feel that my pump is not working as it should...
Now I have checked the Group with two separate gauges and while the Group gauge on the machine reads about 10 the PF gauges are coming in at about 9.
So I am HAPPY with what they are indicating...
However with no PF in place I get the feeling that the water debit / flow is not as strong/large as it first was..
That is I now get about 70ml in 10 sec and 130 ml in 20sec BUT for some reason, I seem to recall it was more earlier on...
This has all come about as I am trying to work out the best grind and dose with the new Vario and I have PERCEIVED that I am getting less volume in a shot than I expected for a 25sec shot... Yet the grind size feels OK, the puck feels sort of OK but under dosed and teh shot is OK but not great.
Now I know Beans and other things come into play... But being a visual person, the flow rate is something that the technical part of me has identified as a change... It may be better and now other things need to be adjusted...
But a confirmation from others as to their flow rate etc would help to set a base line.
Thanks.
AM
